Spec-Ops + NMSFNO = ???
Will this sheath hold this beast? I have one and need to know if I need to get moving on a new sheath order!!
Any help from the hogs out there would be greatly appreciated!!
im guessing with the extra blade length the spec ops will be just a bit too short.
the reg sfno's fit perfectly though. i dont recall having to reshape the insert.
The one I have is just over 8" in sheath depth. I am more concerned about the width of the knife, but if the regular SFNO's fit, then I should assume these will too?
fits just perfectly if you remove the screw. the insert of course requires a little stretching, but not as much work as for the ash
width should be the same, i dont have an nm.
i think the blade length is the cutting edge, which is 8". add the choil and you are at about 9". the tip will likely scrape against the retention screw on the bottom of the sheath.
mine fit in the sheath all the way to the scales.
hi,,just got my nmsfno and it would not fit my spec ops..the blade i too wide.it would take some major tweeking,so i got a buy brown kaydex for it.
I know I was able to fit my Heavy heart FSH into a large spec ops sheath, although you will have to do the oven/ duct tape/ diswashing liquid thing. I don't know. I think the FSH is 7.5" whereas the NMSFNO is 8" ?
