Special Damascus with history
Finally finished a billet I've worked five days on over the past 6 weeks.
Started out with some nails and a couple other relics from San Jacinto, shortly after the battle where Texas won its independence in 1836.
After soaking the nails in vinegar for a few days, then brushing off the rust, I built a canoe to put them in. The flat sides are 1/4” 1084, and the short sides are mild. Inside the can, I put some of the nails and some 1095 powder.
From that point it’s just a lot of weld, draw, restack, weld. This is the San Jacinto nails billet stacked at 19 layers.
Final billet set up to weld.
301, nickel, 1232, nickel, 301. Weld it up, and I’ve got 1836. I did incorporate four layers of nickel sheet in the cladding. Ought to make some nice bright lines on the top half of the blade.
You can see where I used layout fluid and marked the lines where I wanted to mill grooves for pattern development.
Here’s the grooves.
Reveal!
Quick check of pattern at 120 off the grinder.
I did grind it a little more after these pictures, to try and get the nickel line up further from the edge on the front side. Still have at least four full days work on this one before final completion, maybe a few more. Goal is to be done by mid summer.
The next trick will be to find some wood with equal history. The grape shot in the first pic may end up a guard or a spacer, depending on how it rolls out.
Fun development, although it’s still a bird in the bush and not a bird in the hand. I think I may end up with some wood from tree where Sam Houston and the Texan army camped on the first night of the runaway scrape, March 13, 1836. I talked to the landowner and he said he would send me a log.
Would there be any provenance to accompany that? The guy could just send you a chunk of old fence post. ;)
I have asked him for a letter, yes. Plus all the hoops I had to jump through to get to the actual guy, LOL. I finally found the number of the land owner himself and talk to him personally. Seemed like a cool guy, and was interested in some knives for his family members made from the tree as well.
