Special Sharpening
So I was thinking about how a sharpening stone is basically just a rock. Now it's a special rock (hard, special shape, etc.) but a rock none the less. So if you had to go a long time without a sharpener what do you think would work as a substitute. I know it would be bad for the knife and it would never be as sharp as it once was (it would surley ruin a factory grind or whatever). However, if your knife was dull and you knew you couldn't use a sharpening tool for a while it may be better to take the plunge, so what would you use? (obviously this is hypothetical, I just liking thinking outside of the box)
Here is what I can think of off the top of my head: a rock, concrete (if it was smooth enough), a flat piece of metal.
Any round piece of steel (screwdriver) can be used to steel a knifes edge.
The edge of a car window can often have a gritty texture that is great for touch ups.
The bottom rim of ceramic cups and dishes is often left unglazed. This is also great for sharpening.
Many hard/ smooth objects can be used to hone or "steel" an edge.
Steel it on the back of another knife
wet stick rubbed with mud and sand
wet rope or cloth with mud as strop
glass dust on a flat surface
rotating tire as a buffer
ceramic cup or toilet tank cover
The flattest surface of concrete I could find. Stropping would be done on cardboard, leather, jeans, or paper. If push comes to shove I might use the hard anodized coating on my Surefire flashlight:D.
Lotsa farmers here in the Philippines use fine dust on a flat piece of wood to touch up their sickles.
