Specific Fixed Blade
I'm looking for a fixed blade with very specific dimensions:
--handle 3 1/2-4" tops
--blade 4-4 1/2"
Basically something like an Izula II (which I have) but with a longer blade but same size handle.
For light household use, like cutting boxes.
Want to spend up to $100 or less.
Why not go to the knifemakers section for fixed blades, and have one made for you?
There might even be one for sale on there that fits your specs.
Larry Withrow is just one of many names you can look at.
Should be able to make that work in your budget, just need to figure out handle/blade material....
If you don't mind a thicker, heavier knife check out the ZT 0121. 4.25in blade 8in overall. Probably will be a little over budget though.
Checking out the knife makers section is a really good suggestion.^
(DP) Drop Point 4 3/8 L6 tool steel, differentially heat treated
http://www.svord.com/
