Speed Safe..Holding up?
Well the Kershaw Speed Safe knives have been out for some time. For you that have had one for awhile, how are they holding up?
Mike
Quite well, I pop my Blackout habitually about 15 times a day, and pop it for use about 5 times a day, i've had it for about a month and a half now, it's still in good shape, though I had to tighten up the pivot screw 'cause the thing got too loose, but some of this can probably be attributed to the fact that i've dropped it about 4 feet on hard surfaces on about 3 or 4 occaisons.
Also i've every confidence that if/when my Torison Bar breaks,Kershaw will speedily fix it free of charge.
Quite simply, i'm planning on another speed-safe or two in my future.
I've had my Ricochet now for about 10 months, and nothing's broken or loose yet. Surprisingly the pivot has stayed perfectly adjusted. I first few weeks I had the knife I compulsively played with it, probably cycled it a couple hundred times a day. Then it settled down to 50, then 30, then 20, and now about 5-10 flicks/day. The only thing that's strange is a rattling noise if I shake the knife when the blade is open, this developed after a couple months. My 3 month old Boa started rattling recently too, maybe it should be called the "Rattler" :)
Other than the rattling, everything else is good, no liner lock wear or anything.
I like speed safe knives but my results have been mixed. My Riccochet works well but has bad vertical play. The same is true of a few otherss I have. Some also have developed noticeable rattles like my Boa. The Blackouts and Mini-Task, however, have been flawless.
I've had my boa for about 5 months and no problems whatsoever. I routinely take it apart clean it and replace the grease (it probably doesn't need it but i just can't leave things alone) the black coating from the factory looked spotted and uneven so I polished it all off so the blade is shiny and I polished the liners. it has absoloutely no blade play and snaps open quicker than it used too since I polished it(maybe that's just wishful thinking but it definately is fast) I put grip tape on the clip and on the handle because I felt the aluminum was a bit slick. with the improvements I have made I have turned this into my definate favorite EDC and i'm very happy with it
. . .18 months ~ and not a single problem ! The snap of the blade action is crisp and extremely strong.
Have been very very pleased with this selection of my "Every Day Carry" line-up ! :D
Well, I posted a while back when my Chive broke; some of you may remember that. It just stopped flicking one day; I heard a sort of *snap* and it would no longer flick at all. I haven't sent it in yet, simply because I'm too lazy. Don't let this put you off a SpeedSafe, though. One guy here talked to someone at Kershaw and they said they've only had ten returned out of some 70,000 shipped. So, I think they're good deals, and I just got a lemon.
Asha'man
No dis-respect intended, but the adding of springs to a knife only
increases the "toy" factor. I can tell you from experience that the
darn spring will break or get weak when you need the knife the most.
That is why knives with a hole in the blade or a thumb stud will be
there when needed with NO loss of speed or ease of opening.
A butterfly knife , a spyderco or a thumbstud knife always will
be the safest, surest, knife to carry / use for daily use. That or the
good old slipjoints / lockbacks.
I personally don't care for any of them, but have many friends that love them! The only problems I've heard have been related to vertical blade play (definitely unacceptable), but I also don't know if "use-abuse" was a factor in the two cases I'm thinking of.
"Hunters seek what they [WANT].., Seekers hunt what they [NEED]"
