Recommendation? Speeding up sanding.
I am finish sanding the underside and sides of a bowie guard and it is going amazingly slow. I am using round bar and sanding sheets and because of the small contact point, the grit is gone in 2 or 3 passes. But I am hesitant to go to rubber or leather covered bar yet because I don't want any lumps or pits.
Have any of you found a way to get the rough filing marks sanded away and to a medium grit quickly? Like I said, I don't want to use a soft backing yet... I like to start with a soft backing at 400 grit to keep things smooth.
small wheel adapter on a 2x72 or small wheel on horizontal grinder
that's how I've done it
and with those 1" scalloped belts.
slow speed
or I use leather backed with lower grits just fine
I really need to build a rig for a small wheel on my grizzly. It would be super helpful.
I have some spindle sanders, I'll give that a try.
I actually saw a pretty ingenious idea. A gyy made a fixture that would hold an small chisel grind sanding block inside an air hammer. Mind blown
