- Oct 25, 2002
This bad-boy has a 4-1/2" saber ground blade made from 3/16" thick high carbon steel. The top/spine of the blade which is unsharpened has a slight curvature or persian style geometry to it, and the blade is 3/4 of an inch at its widest. I also applied a semi-permanent clear protective coating to the blade.
The handle is wrapped with paracord in the Kaifu Zuka fashion and then soaked with resin, making it hard and liquid resistant.
If you look closely at the picture, you can even see a slight hamon running the length of the blade.
Hope you enjoy
