- Jul 22, 2000
Im wondering if some of these tests that some manufacturers use to promote their knives (as well people in these forums use to determine whether a knife is worthy) like spine whacking are overkill? Do these tests reflect real life situations?
Now let me be the first to say that I support the underlying principle of evolving products to make them better. Im also against cheap products that are dangerous to consumers.
However, how often are you going to find yourself in a situation when the spine of your knife blade is getting 200 lbs of pressure put on it? Obviously Jones, youre using your knife upside down!
Even in the case of exerting force on the tip: Forget 200 lbs. If it's even 100 lbs of force, it seems to me that you are in more of a danger of your blade snapping, or losing your grip and running your hand up the blade of your knife (ouch!). No extra thick 410 SS liners, or a safety Axis lock is going to save you then.
In addition, youre not going to be using a $300 folding knife as a chisel, or a slotted screwdriver. If youre doing that, may I suggest that you save yourself a few bucks and pick up a $50 tool-kit from Wal-mart. This brings me to another point: Warranty is void if knife is misused.
Many of these manufacturers build and advertise their knives as being able to survive a confrontation with a Sherman tank. However, theyll void the warranty if you so much as use your knife as a scraper to take frost off your car window!
NOTE: This post is not to "flame". It's just a commentary. I just bought a BM 710 but I question how often I'd use the Axis lock.
