You posted this while I was typing my comment. You said basically what I was thinking. Very well said. I'm pretty sure we agree.I like them in 58mm
I don’t mind them on larger frames like 111mm, even if I rarely use the rings
I generally dislike the associated lug protruding from the knife in most 84mm and 91mm. I’ve removed many from users and mods because I find they get in the way and I tend to pocket carry. Even hacked some off of somewhat otherwise rare/collectible users…like a 1st generation pliers (2.5mm wide) ‘87 Craftsman.
Almost hate the ones on the 93mm. Again, mostly for the associated lug which is the absolute worst of the bunch at digging into my palm during use or snagging things.
And for any split ring…snagging things like pocket threads is just the cherry on top.
I do too!!I like the rings. I usually replace the ones on 93mm models with a smaller one from 58mm model. Less floppy.
Great idea. Victorinox used to put the smaller split rings on 2-layer 84mm alox.I like the rings. I usually replace the ones on 93mm models with a smaller one from 58mm model. Less floppy.
Took me decades to decide to take the ring off my original ‘84 Champion. On some models the negative reaction and feedback was almost immediate. Like on the first key ring Farmer I used. Instant feedback that turned the wood saw into more of a pull only saw.It's interesting how some find that the key ring and the protuberance from the liner that holds digs into their hand in use. I've never had that problem and it didn't occur to me that it might be a problem, but it clearly is for those individuals.
Good point and maybe there is a market…but Victorinox has a long history of reducing such options and I doubt frames like 91mm will get the lug-less backspring needed for the delete.There truly is no such thing as "one size fits all." I know Victorinox made "economy" versions of some models in the past without the key rings, but I don't think they do any more. Maybe there is still a market?
where did the pin and magnet go?I used to sell 30lb rated split rings with a magnet and pins as an upgrade. I sold heaps. I like the split rings, very handy.
View attachment 2200735View attachment 2200737
