- Mar 19, 2007
Background:
I took delivery of two Swedish Army Axes on Friday from Sportsmans guide. I opened the package - was really pleasantly suprised - and set them aside until later that night.
When I finally got them out and into the garage - it was dark. I had time enough just to snap a few photo's and begin to see what type of Axe they were, what condition they were in, and how much work I was going to need to put into them. I had two axes and this portion of the thread will focus on the first one I began to work on.
I made the decision to work on the axe with the single wedge first. Both handles were loose - and I knew the epoxy was going to suck - so, this being the first time I have ever rehung an axe, let alone refurbished one, I thought I would take it easy.
The first thing that got my hopes up was that the one I was about to work on had really good signs of grain in the handle:
I clamped it up into the vise (with leather) and gave it a shake or two to see how loose the head was - I was stunned when the wedge pretty much popped out:
It certainly was not in there very deep - and I couldn't believe it came out that easy. But - with very little work, I had the axe handle free.
I used a random orbital sander and 100 grit paper to simply knock off the paint. As you can see, this one appeared to be unissued and is marked "KB 42" like so many others. Who knows where it was made - but it appeared to be great steel - well made - and we would have to see how well it would hold an edge.
Day One:
I got up on Saturday eager to see what was under the nasty green paint. I got some tools around and then started to take some measurement photo's for Posterity.
Weight: 2 Pounds 92 Ounces.
I tried to keep the square as even to the base of what I was measuring - the measurements should be fairly true:
Here is a shot of the nasty green paint on the handle:
You can see the brand from the three crowns here. It looked good - I hoped the wood looked as good underneath it. Sanding time.
Sanded to 110.
Sanded to 220.
At this point I knew this handle was essentially in perfect condition. I had gotten very lucky. The grain was strait - it was sapwood - it had no defects or rot and the wedge popping out left the top in perfect condition. I cut the curf a little lower and set it aside to be worked on after the head was done. I was really excited.
I took the head over to my table top belt sander and took my time, soaking the head in water every few minutes and ensuring that the steel never got warm to the touch. I decided I wanted this one to be more polished than the other. So I spent quite a bit of time on the sander just taking off rough spots. It would have been very easy to wire brush everything, leaver a nice wire finish on it and start to profile and sharpen it. However, polished it was - so after much sandingI tossed the head into the sink with a LOT of vinegar and some water.
Here is what it looked like after I took it out (perhaps a two hour soak) and cleaned it up with a wire brush:
After I took it out of the water - I cleaned it up again with hand sanding and then used a cold blue chemical to force a nice black patina:
That was day one - stay tuned for Day two - and the other axe... it has a suprise waiting for us.
TF
Day One:
Sanded to 110.
Sanded to 220.
TF
