The best way that I have found to treat old
car springs is to take the chunk that I want
to make into a knife and heat it to critical ( and don't worry about temp. because most
pieces of old springs will go critical at different temps.---use a magnet to tell when
it goes non-magnetic (critical))
then put it into some sort of fire proof insulation and let it cool down very slowly.
Then forge or if you can't forge anneal it
another time. If you forge heat to critical
at the end of forgeing and let air cool then
anneal twice. Hardening should be done at
critical (non-magnetic) and if you can quench
1/3 to 1/2 up from the cutting edge in heavy
mineral oil or Conoco pale parifin quenching
oil if not point down quench the whole thing.
Repeat process twice letting the blade cool
to room temp. between process. I heated the oil up to about 165 deg. before quenching Then temp.
for 1 hour at 350 deg. take out and let cool
to room temp. then repeat. Before hardening
leave about 3/32 of an inch on the cutting
edge it will protect the carbon from burning
on the edge. If you can find someone that
has a liquid nitrogen tank and will let you
put your blade in after final grind for about
an hour or two then temper again at 340 deg.
you should have a very tough knife that will
also hold a very good edge. The higher tempering temps. will make your knife softer
and more flexable but will hurt your edge
holding capability. I've treated knives this
same way and have been able to put them in a
vise and bend them past 90 deg. and then back
the other way past 90 deg and not have them
break so what is the sense in making them
softer???? I've also chopped through hard
Oak and not had them chip.........
http://www.imt.net/~goshawk
Don't walk in tradition just because it feels good!!!!!
Romans 10:9,10
Hebrews 4:12-16
Psalm 91
[This message has been edited by goshawk (edited 11 September 1999).]
