File are normally 1095 or W-1. Many leaf springs are also 1095 or 5160. You need to draw the file back probably 550-600f would do the job. May I ask why you are trying to make a spring put of a file? Or are you trying to make a knife out of spring steel? If you are attempting the latter then you can draw the file at 400-450F to give you 58-59RC. Then do your grinding very carefully as to not overheat the material.
Interesting. Everywhere I've been, it's much easier to find old springs than almost anything. I'd be walking down the road and one would randomly fall out of the sky. I'd have to pay people to haul them away from my doorstep because drifts of them would spontaneously accumulate overnight.
I may have to try this to get rid of some of my small files, I really like the idea. I would like to keep some of the teeth on the blade but not on the spring, or turn sideways but a cool idea maybe with some antler.
Seems like it should work fine, assuming you have a file made out of some decent steel (not some cheap case hardened thing) and get the shape and heat treat right.
