- Dec 5, 2005
Greetings and Salutations!
this lil guy's name is 'Spud', and it's magical power is to disappear when not needed and then reappear when something needs to be cut!
The Richlite handle scales are bonded to G10 liners, which are held in place to the canvas micarta frame with 4 2mm stainless steel pins, two canvas micarta pins and one brass tube. There is no metal touching the tang, so the handle is always warm and inviting, and may not shock you quite so bad if you cut into a live wire, (pro tip- don't do that!)
The S35VN blade has a belt finished hollow ground primary bevel, with a hand worked, fine appleseed shaped secondary bevel/edge. Hand rubbed flats. It's cryogenically quenched for maximum radness.
Sheath 8oz veg tan leather, dyed and hot packed in-house, and hand stitched with chubby, waxed polyester thread.
Thanks for checking out my work, your comments and questions are welcome here.
Cheers!
Cheers!
