Codeman,
I'm afraid your misunderstood both Joe and Sal. It is no matter to sharpen the edge to 30
or 40 degrees. Your edge has to have
two bevels - one with 30 degrees and another with 40. I'll try to explain in some pictures.
Here you can see how properly sharpened edge looks in crosscut.
Area
1 is the
main cutting edge with 40 degree bevel. This is the optimal angle for most utility, working or tactical knives. Sharper angle will make the edge sharper but weaker. Less sharp beveling will make the edge stronger but will affect sharpness.
Area
2 is so called
back bevel or
thinning bevel. It reduces cut material resistance thanks to the lack of pronounced angle between main edge and the rest of blade's side surface.
Area
3 is the blade's main grind. It is as manufacturer has ground it and here you can do nothing when sharpening.
Here you can see how Joe is proposing to sharpen the edge. First you must create the single bevel with 30-degree sharpening angle until the burr on the opposite side will show you the bevels are meeting themselves. Now you must remove very sharp but weak "tip" of the edge grinding it to 40 degrees. I marked this area with dark color.
Here you can see how to obtain the same result following Sal's advice. First you have to crate the main edge grinding your blade with 40-degree sharpening angle. Later you have to remove the shoulders between the edge and blade's main grind grinding it at 30 degrees (two dark areas on my picture).
Comparing these methods: Joe's method is more accurate but wasting more edge's width. If I would make new knife myself I would use this method. However I'm too greedy to waste so much steel
so sharpening production knives I use Sal's method.
As to Shaprmaker, it is the simplest and the most cost- and result-efficient sharpening device I know, ideal for beginners and very useful for experienced sharpeners.
But bee careful - don't allow your tip to slide down from the rod, especially used in the "edge" mode. The last some millimeters of the tip must be sharpened using Sharpmaker in bench stone mode.
Sergiusz Mitin
gunwriter
Lodz, Poland
[This message has been edited by Sergiusz Mitin (edited 04-29-2000).]
