For plane blades you should try waterstones. A 1k and 6k wold serve you we'll.
The UF ceramic a good stone, I just don't think it would be a good fit to the sharpening you have planned.
I go from my EF DMT to a fine spyderco, it's about 2400 grit so it's already a step up from the EF DMT. The extra fine spyderco is ~5k.
The UF spyderco is more of the 8-10k range.
I'm starting to think I may just follow the progression to the EEF stone
I was typing while you posted this, follow your instincts, and have fun! Russ
Numbers only get you so far, what stones actually do to steel is a different story. Compare a waterstones, oil stone, ceramic and diamond at the same micron rating and they will all produce a different finish
