- Jul 2, 2000
I was at knifecenter today and took a look at one just for fun and was very surprised! Steel liners and torx screw construction with an adjustable pivot?!!!!!!!!!!!!!!!!!!!!!!!!!!! WOW Spyderco finally did it. So I looked a little harder. It had a thicker tip on it's VG-10 blade and a cool spyder etched into the blade. The new pocket clip is well made and can be attached on either side, tip up, or tip down. The new Delica is noticable heavier due to the steel liners instead of the old all plastic design. Opening and closing is very smooth, and the lock is very secure. The lock release has the detent on it that the Spyderco MBC knives have. This new version is far superior to the old and although I was skeptical due to the photos, after I held it I was sold. At a street price of under $50.00 you can't go wrong. The below info is from knifecenter.
[FONT=Arial, Helvetica, sans-serif]length overall[/FONT][FONT=Arial, Helvetica, sans-serif]7 1/8" (222 mm)[/FONT][FONT=Arial, Helvetica, sans-serif]blade length[/FONT][FONT=Arial, Helvetica, sans-serif]2 7/8" (96 mm)[/FONT][FONT=Arial, Helvetica, sans-serif]blade steel[/FONT][FONT=Arial, Helvetica, sans-serif]VG-10[/FONT][FONT=Arial, Helvetica, sans-serif]length closed[/FONT][FONT=Arial, Helvetica, sans-serif]4 1/4" (124 mm)[/FONT][FONT=Arial, Helvetica, sans-serif]cutting edge[/FONT][FONT=Arial, Helvetica, sans-serif]2 9/16" (88 mm)[/FONT][FONT=Arial, Helvetica, sans-serif]weight[/FONT][FONT=Arial, Helvetica, sans-serif]2.5 oz. (71 g)[/FONT][FONT=Arial, Helvetica, sans-serif]hole diameter[/FONT][FONT=Arial, Helvetica, sans-serif]1/2" (13 mm)[/FONT][FONT=Arial, Helvetica, sans-serif]blade thickness[/FONT][FONT=Arial, Helvetica, sans-serif]3/32" (3 mm)[/FONT][FONT=Arial, Helvetica, sans-serif]handle material[/FONT][FONT=Arial, Helvetica, sans-serif]FRN[/FONT]
From the Spyderco website:
In 1990 Spyderco shook things up by introducing two knives, the Delica and Endura. First of their kind on the market, both folders opened up the knife market to lightweight performance, one-hand open pocketknives that just about everyone could afford. They settled as Spyderco’s top two bestsellers and their improvement hasn’t slowed since. Refinement has been so ongoing and continual Spyderco tagged the updating/upgrading process with the term CQI- Constant Quality Improvement. During the Endura and Delica’s CQI journey Spyderco tweaked ergonomics, refined blade steels and fine-tuned their performance countless times. They are an evolutionary work in progress and the next level is here with the new Endura4 and Delica4. Both models now have screw construction making cleaning and adjusting easier. The fiberglass reinforced nylon handles come molded with Bi-Directional Texturing® for preferred traction and improved ergonomics. Inside the handle dual skeletonized stainless steel liners make the knife stronger without adding weight and make an anchor for all external and internal components to attach through adding sturdiness and rigidity. Their VG-10 blades are flat saber-ground with a stronger tip and larger 13mm opening hole. Added to the blade’s spine is slip resistant jimping. Phosphor bronze bushings smooth out the open/close action and the clip is upgraded to a four-way tip-up, tip-down, left- or right-handed clip.
