Thanks to Sal Glesser, Spyderco and Dave H. for another great pass around!
DETAILS Details from Spydercos site -
http://www.spyderco.com/dealer_prod...1010&mscssid=HTJ3LAM1WP1D9NP8DGB2QSRHBXEWBCU4
OUT OF THE BOX - My first impression was that the ATR is a good sized knife but very thin and lighter than it looks (4.9 oz. nominal). The ATR fit my hand well and opened easily using the Spyder hole/ Cobra hood. The blade is easy to unlock and fold, but the compression lock took little getting used to for me (just because the lock is on the top of the handle).
The ATRs fit and finish are first rate. The blade has what I would call a satin finish - more highly polished than the S30V Native, but not mirror polished. The ATR came with a very sharp factory edge that would shave easily and cleanly.
LOCK The ATRs Integral Compression Lock is similar to a frame lock except that it locks the blade from the back instead of the front. The Compression Lock appears to be very strong and stable, as there is practically no way to twist or bounce it out of engagement as is sometimes possible with some liner or frame type locks.
The Compression Lock is easy to disengage when you want to close the blade, but it requires a little different technique than a frame or liner lock, since the Compression lock is on the top of the handles. To close the ATR, I used the same technique I use for lock backs: release the lock with my thumb then start to fold the blade by brushing it along my leg and finish by pressing on the spine with my thumb.
BLADE The ATRs 3 7/16 Hollow ground modified-dagger tip blade as Spyderco describes it, is a bit unlike any other blade I have used. The blade has a hollow sabre grind with a good amount of belly and a sharp point. The unusual part is the concave curved spine with a little fin shaped hump near the tip. I dont know what the fin is for, but it looks like it would help keep the point from snagging when opening up the belly of a game animal.
The ATRs blade is about .123 thick at the spine and about .022 thick behind the edge. The factory edge angle is about 13.4 degrees per side on average.
I found the ATRs unusual blade to be quite useful, although I would prefer a full flat grind.
STEEL The ATRs blade steel is S30V. Some of my comments on S30V in the Native review that can be seen here -
http://www.bladeforums.com/forums/showthread.php?s=&threadid=268455&highlight=spyderco
More importantly, heres a thread with some excellent information on S30V from Sal Glesser and others -
http://www.bladeforums.com/forums/showthread.php?s=&threadid=270056
More information on S30V is available on Crucibles site -
http://www.crucibleservice.com/cutlery.cfm#
HANDLES - The ATRs handles are lightly brushed Titanium. The ATR was comfortable and secure in the standard sabre, hammer and reverse grips. The ATR is also designed to be choked up in the sabre grip. The ATR feels awkward in the palm reinforced sabre grip, since the rear of the handle is too square and angled the wrong way to nestle into the palm comfortably. Also, when I tried the palm reinforced sabre grip my thumb was resting on the lock and I suppose that I could release it in a panicked white knuckled grip. All other grips seem to make accidental lock release near impossible. The combination of the Cobra Hood, the finger groove and the beak on the rear of the grips lock the hand in securely, so the palm reinforced grip may not be needed for preventing the hand from slipping on to the blade when stabbing.
Although comfortable, the ATRs grip is quite slim, measuring 3/8 across the scales and about 9/16 including the clip.
POCKET CLIP - The ATRs wide uncoated steel tip up clip is revisable from right to left and appears to be very sturdy. The ATR clip is not flat like most clips; its edges are turned inward. The ATR clip gives a tight grip on a pocket in fact it was a just little too tight for blue jeans.
While I prefer tip down clips, the ATR felt less awkward to me than other tip up knives. Despite its size, the ATR was nearly unnoticeable when clipped against the rear seam of my front pocket, thanks to its thinness.
COBRA HOOD - Why didnt someone think of this a long time ago! The Cobra Hood (which, if Im not mistaken, was first used on the Salsa) seems like such natural complement to the round Spyder hole, I miss not having it on other Spyderco knives. The Cobra Hood not only gives your thumb more purchase when opening, it helps index your thumb to the hole.
CUTTING PERFORMANCE - I used the ATR a good bit in the kitchen chopping up veggies and cutting up stew meat. The ATRs hollow saber ground blade worked great for cutting meat and did well on the vegetables, but I would have preferred a full flat grind.
I also fooled around with a few slashes and stabs to a piece of beef which left me with no doubts that the ATR is capable of producing vicious wounds if used for self defense.
Getting back to more mundane testing, I used the ATR to slice up some cardboard. The ATR went through the cardboard quickly and easily with no issues with handle discomfort.
I went on to make a fuzz stick and point a stake (both seasoned oak), the ATRs blade shape was not perfect for these tasks, but the ATR got the job done, again without discomfort.
RUST RESISTANCE After using the ATR in the kitchen, I washed the blade with very hot water and dried it off thoroughly with paper towels before clipping it to my pocket. Well, I obviously didnt dry it near as thoroughly as I thought; since when I pulled the ATR out a couple of hours later, there were two small/ faint rust spots on the blade. These spots (thankfully) disappeared completely after a bit of rubbing with a pencil and some Tri-Flow. Aside form this; there were no problems with rust.
SHARPENING/ EDGE HOLDING The ATR held its edge very well. I did not have to sharpen or touch up the ATR at all while I was using it. Before sending it out I gave it a very light touch up to bring the edge back to close to the factory sharpening, but it was still shaving well and really didnt need sharpening.
CUT TO THE CHASE - The ATR deserves some serious consideration for anyone looking for a high end EDC with hard use capabilities.
Thanks again to Sal Glesser, Spyderco and Dave H. for the pass around.
- Frank
Here are some links to other Spyderco pass around reviews -
Temperance & Impala
http://www.bladeforums.com/forums/showthread.php?s=&threadid=263754
Native Lightweight C41BK
Lil Temperance C69
http://www.bladeforums.com/forums/showthread.php?s=&threadid=270637
Chinook II C63GPS
http://www.bladeforums.com/forums/showthread.php?t=293968
Jester & Ladybug with Photons
http://www.bladeforums.com/forums/showthread.php?p=2499036#post2499036
- Frank
Temperance & Impala
Lil Temperance C69
Chinook II C63GPS
