Spyderco and Kyrstolo synthetic hone identification
Anyone recognize either of these two synthetic hones? I am especially interested in learning actual grit size equivalent and material. The Spyderco was purchased in the early '80's from a knife shop. The Krystolo was inherited from my Grandfather, which he used to sharpen his straight razor back when that was the standard tool for shaving.
I've had these two hones in my knife drawer for close to 35 years. Both were so horrible clogged as to be useless. Just the other day, I became interested in trying to rejuvenate them. I ran them through the dishwasher, scrubbed with a Scotchbrite and liquid detergent, and, finally, hit'em with a Scotchbrite and Barkeepers Friend. The latter really did the trick in cleaning them up. Indeed, the results of the Barkeepers Friend was impressive.
The Krystolo is dished out, so I need to flatten it, too. I am thinking of maybe getting a Naniwa Flattening Stone for this, or would the Naniwa be good only for use on water stones?
Any info beyond what is printed on their respective boxes would be appreciated.
TIA
It looks like the Krystolo was a Pike product. I wonder if it's silicon carbide...simply because of the similarity to the Crystolon name used by Norton.
Hi,
That stone seems very niche even for waterstones.
What will you do when the Naniwa Flattening Stone dulls?
Well then you need loose grit abrasive on float glass/tile ,
might as well get that from the start :)
More in this recent thread flattening-a-big-hard-black-arkansas.1586084
and
Re: Large NANIWA Flattening Stone Grain Size 220 - size matters!
Not the best way to recondition the surface of an arkansas stone but it worked - slowly.
And you risk to smooth out your lapping plate.
2. glass and abrasive grain - 150 grit sic powder do what 220 naniwa did for 5 minutes for just under 50 seconds
