- Jul 7, 2002
I picked up a Spydie Karambit this weekend at a local knife shop to keep my custom WT company. I am mucho pleased with it and I think it will be a mauch more practical knife than its stealthy brother. Took these pics this morning before work, just found time to chop em and upload em now.
click for high res goodness:
this is my fav pic so I'll start with it...very Yin and Yang
side by side, open. Notice that the Spydie has a bit more of a curve and slightly softer lines.
side by side, closed. I think I may smooth out the spydies hole a bit cause it has a bit of lazer-splash in th inside.
Lock side. Notice that the Warrent Thomas has a bit more robust a lock. Both lockups are as solid as can be with no sticking or bladeplay of any kind. I love it.
Top-down, closed. Notice that the bushings in the WT make for a wider handle.
Top-down, open. To show the locks, I think the spydie's liners are a bit thicker, but look thinner than they are because they are beveled. In fact the non-lock side is considerably more beveled than the other. The Ti-version also has thicker liners than it appears in photos but is equally beveled on each side.
I carried the Warren Thomas for a little over 2 weeks using it for all my usual cutting chores. It is not as sharp as I would like and I am reluctant to try and sharpen it due to the strange nature of its cutting edge. It does cut thru plant material extremely well, I would reckon becuase of microserrations. The Ti version is much lighter, but this also means the blade has no momentum for deployments. The Spydie cuts great! It is evenly ground sharp VG-10. The clip on the spydie comes for tip-up wich means a huge shiney ring will be sticking a little less than 2 inches out of your pocket. The Ti version is nearly invisible, the small amount that sticks out is very light-absorbing due to the beadblast and anodization.
Thats all for now. Please share your thoughts, pics, or any questions you might have. I will be putting the Spydie thru the rigors of everyday cary and will add my observations as the come. It is great to have one for each hand now, karambits are a blast to play with.
