kreole
- Jul 23, 2009
Spyderco Atlantic Salt (PE, Black Handle, BNIB) $45
Spyderco Atlantic Salt, Black Handle
This is a brand new knife with the box--factory everything, never carried, etc.. I bought it as a back up when I heard they were being discontinued, but I'm tired of it sitting around already. It was sitting in a drawer and seems to have picked up some scuffs on the clip (they don't go down to the metal) and chipped off paint at the screw.
Busse Sar 3 (Orange/Black G10) w/ sheath - $180 Sold
Cold Steel Mini AK-47 $30
Cold Steel Mini Lawman $30
Take both for $50! Sold
Spyderco Tasman Salt (PE, Yellow Handle) $40 Sold
Busse Sar3 + sheath
I bought this off the exchange brand new. When I got it, I hit it with 500 to 2000 grit sandpaper and as you can see in the pictures, the finish is cleaner than from the factory, but the grain of the steel still shows. It made the logo lighter (I tried to show that in the pictures). I also made a kydex sheath for it, and that has left some marks near the spine (not scratches, just scuffs). The sheath is pretty good, and the rivets are set up for a Spyderco G-clip (not included), which I believe is made compatible with small tek-lok clips. After I made the sheath, it sat in a drawer, so it's unused.
http://i.imgur.com/BG72m.jpg[/IMG
[IMG]http://i.imgur.com/xtdme.jpg[/IMG
[IMG]http://i.imgur.com/iMTzm.jpg[/IMG
[IMG]http://i.imgur.com/5uPbu.jpg[/IMG
[IMG]http://i.imgur.com/mNPb6.jpg[/IMG
[IMG]http://i.imgur.com/LpaHK.jpg[/IMG
[IMG]http://i.imgur.com/q00mD.jpg[/IMG
[IMG]http://i.imgur.com/fvEBH.jpg[/IMG[/COLOR]
[COLOR="silver"]Cold Steel Mini AK-47
I bought this off the exchange a few weeks ago and haven't used it. I took off the ugly blade coating with 0000 steel wool and hit it with 2000 grit sandpaper (though it still has some light scratches from the steel wool). I only did the blade--not the thumb disc and not the lock bar. Centering is nearly perfect while keeping the pivot loose enough that it's quite smooth opening, and there is absolutely no blade play. There are some scratches on the peek of the clip and on the end at the edge. The edge is hair whittling sharp with a mirror finish (it's from the previous owner, so I don't know if it is the factory edge). Comes with the box (it's got some dents/bends in it, though)!
[img]http://i.imgur.com/kWNK7.jpg[/img
[img]http://i.imgur.com/09NPr.jpg[/img
[img]http://i.imgur.com/ql0Gt.jpg[/img
[img]http://i.imgur.com/xMfQ5.jpg[/img
[img]http://i.imgur.com/Wdyub.jpg[/img
[img]http://i.imgur.com/VcphA.jpg[/img[/COLOR]
[COLOR="silver"]Cold Steel Mini Lawman
I bought this off of the exchange with the blade and lock bar already stripped. The blade has a hand rubbed sandpaper look to it (IIRC, 1000 grit sandpaper was used). There are slight gaps/knicks on the G10 where the blade is when locked due to it being apart that do not affect anything. Blade centering is almost perfect. The edge is shaving sharp with a mirror finish. The clip is nearly perfect, so I doubt this was carried by the previous owner, and I never used it, either. Comes with the box!
[img]http://i.imgur.com/pF4IJ.jpg[/img
[img]http://i.imgur.com/NVHS9.jpg[/img
[img]http://i.imgur.com/W6Pt8.jpg[/img
[img]http://i.imgur.com/fb0vy.jpg[/img
[img]http://i.imgur.com/X8iM1.jpg[/img[/COLOR]
[COLOR="silver"]Spyderco Tasman Salt, Yellow Handle
This knife was used and carried a few weeks. There are some scratches at the top of the blade from a Lansky clamp. Since then, it has been sharpened on a Sharpmaker and stropped. It's an amazing slicer because the back bevel is 25* inclusive, and the edge is 30* inclusive. There's no up and down play. Side to side there is a slight amount if you push it, though the back of the blade never leaves the lock bar, so it's really just shifting in the handle. Centering is nearly perfect, just a fraction of a millimeter to the right of center. No box! (I forgot to put the clip on before taking the first few pics, but I took one of the clip itself, which is at the end; it's in good shape except there's paint scraped off from unscrewing it and some small chips missing from the top edges.)
[img]http://i.imgur.com/nBuDu.jpg[/img
[img]http://i.imgur.com/kEnOV.jpg[/img
[img]http://i.imgur.com/eo6Me.jpg[/img
[img]http://i.imgur.com/0IbKW.jpg[/img
[img]http://i.imgur.com/KuBNf.jpg[/img
[img]http://i.imgur.com/MJW2L.jpg[/img[/COLOR]
Busse Sar3 + sheath
