Even $90 for ats 55 is expensive unless its in immaculate condition. You can find user enduras for $60 in vg10 if youre lookibg for a userHe has one in ats 55 it’s $87.50 I guess it’s for collective value?
Not ranch edc , maybe $35-40
OP: I didn't see any pics of what you found. Does it look like any of these?
This is my collection of Gen 1 FRN Endura Clipits. The blade in the knife at the top is unmarked and is made w/Gin1 or 2 steel. The other 3 are all marked AUS-8.
They all have the earlier thin molded plastic clips which were made from around 1990-1996. The clips tended to break and where replaced by Spyderco w/metal clips when they did. Later models were made w/metal clips at the factory to avoid the problem altogether.
However, there were some thicker FRN clip versions made, before they switched entirely to metal clips, which looks like this:
FYI, there is a Forum rule that prohibits giving a specific value estimate for a knife to any person who can NOT sell a knife on the Exchange, which requires at least a Gold Level membership.
Your request for info on the value of the knife you are considering could be considered falling w/in this rule. So, I will not offer a specific value estimate for that knife and will speak only generally on the topic.
If you've got a Gen 1 Endura that requires repair, I doubt that it would worth "restoring." On the other hand, it might be worth sending to Spyderco for repair depending on the extent of the damage and the price you pay for the knife.
However, if the the blade and/or clip has been repaired or requires repair, you'd probably be better off just buying a new or used late model Gen 4 Endura instead.
Thank for the heads up about listing pricing, And yes these are old school clip it’s, in various states of disrepair, I am kinda unfamiliar with some steels , as most of my stuff is vintage gerber 7223’s 440c or cruwear , and D2 , and case or buck carbon steel, except these spyderco I am looking at for edc folder
The new ones are better anyway.
S60V comes to mind...although it’s apparently being made again.I wouldn't say that.
There are a lot of "old" ones are are pretty darn good; most of which aren't made any more.
I was referring to the the Delica and Endura--I think the newer ones are better--better steel, better grinds, stronger, less lock rock. YMMV.
I like the old style with the FRN integral clip.
I had two of the barrel style end up shaving FRN slices from the handle when the clip twisted. Both were replaced under warranty but after the second one I sold the knife because I considered it a design flaw.me too! the FRN clip was nice bc it didnt scratch your car if you brush up against it!
I also liked the barrel-style because I've never had it fail on me. the newer style (w/ 3 bolts), I've broken maybe 3-5 of them. Spyderco CS has always been outstanding with this!
