Spyderco Caly 3 Review
Just got my Caly 3 in today. I chose the Caly 3 over the Mini Manix mostly because of size concerns. I wanted something similar in size and overall shape to my Mini Griptilian because, well, I just love that knife.
First Impressions:
The knife came (literally) shaving sharp out of the box. It really has to be held to appreciate the thought and time that must have gone into designing the ergos. The checkered G10 is nice and grippy, and the knife feels very solid overall. I really like the wire clip, especially after having accidentally 'keyed' my own car with the clip on my Mini Griptilian.
The knife stinks. Either the lube Spyderco uses or the G10 smells strongly, almost like the smell of military surplus gear, but I'm sure in time that will dissipate. It's no big deal, I just found it odd.
It opens with a very solid CLACK! sound, and I instantly found faith in the lock just by opening the Caly 3 for the first time.
The VG-10 has a keen, almost scary edge. I'm interested to see how well it will hold up. Because of the blade profile, this knife feels sharper than the S30V knives I own.
It slices like a demon. One of the reasons I bought the Caly 3 was to try out a full flat-ground knife, and I have to say I'm impressed. I cut up a few plastic bottles, and the way it slid right through them was impressive.
The Spyderhole is much more intuitive and comfortable to use than I expected. This is my first Spyderco, and I found the hole to be perfectly positioned for opening. The Boye-dented lockback is also very intuitively placed, easily accessible by moving your thumb back on the spine. The knife can be one-hand closed quite easily by moving the thumb back and pressing the lock.
This is another well-thought-out point by Spyderco: when you push the lock, the blade drops down slightly, allowing for one-hand closure. Initially, I worried that with wear, the blade would swing further, possibly causing injury. But in actuality, the blade is stopped by the tension of the lock, and even if manually pressed to swing all the way to the finger, there's still part of the finger choil to protect the index finger from the sharpened edge.
A look inside the handle of the knife shows some beautiful drilling of the liners for weight reduction, a nice detail.
The tip aligns within the handle very well when closed. This is nominal, but it's a pet peeve of mine. Tips that don't line up when the knife is closed bug me.
The Caly 3 feels very solid in the hand, and is comfortable to grip either using the finger choil or back further on the handle.
The clip does not interfere with grip, rather it adds some depth to the knife.
Sal's signature on the knife is a nice touch. It's hard to tell from some pictures of Spyderco knives that that small triangle of letters is his initials, but it's very refreshing to see a stylized spider on one side of the blade, and Sal's monogram on the other. That's it. Just a few simple, elegant blade markings.
Dislikes:
Fit and finish are high, but not as high as on similarly or lesser priced knives such as the Benchmade and Lone Wolf knives I have owned. The blade shows some scratches probably from manufacture or inspection. The grind on the sharpened edge is slightly irregular; it doesn't appear even when you look at the knife edge-on. There was also some scratching on the spine of the knife and some circular marring on the G10 out of the box. I also found that the rivets near the spine were unevenly pressed. All of which isn't enough to be upsetting, but enough to be annoying.
The base of the blade nearest the pivot is showing scratches from being opened and closed just a few times since it's been out of the box. I was aware of this issue before purchasing the Caly 3, and it still strikes me as a design flaw, and due to the "washerless" design.
The finger choil near the blade is more shallow that I thought it would be from the pictures. I don't feel this is a safety issue, more of an ergonomic or perceived one.
There are rivets where I would have preferred screws.
Closing Thoughts:
Overall, I'm impressed with the knife. I don't find it quite worthy of the $100.00 I paid for it, but that's partially because I'm used to getting knives like the Griptilian off eBay for around $60.00, and bought the Caly 3 relatively new because I "had to have it" before the resale price went down.
This is my first Spyderco, but it most definitely will not be my last!
***Edited to add Pics.*** Please note, these pics were taken to point out some irregularities with the knife, part of a dispute with the seller. I'm curious to know if these details are standard fit and finish irregularities, or if something else is going on, so I re-posted them here. Please don't take this as "bashing" Spyderco in any way, I still very much like the knife.
Slightly irregular grind:
Some scratching out of box:
Back spacer marring:
Another scratch out of box:
I'm curious to know if these are common on the Caly 3. There were a couple other scratches on the blade out of the box that I couldn't photograph.
Again, I love the knife, and if these are unusual irregularities I'd be hesitant to send it back and have to be without it! In fact, I think the quality and subtle design of the Caly 3comes through more than anything else in the above photos. :D
Thanks for the review. Well done. I've been a Caly 3 fan for many months now and I've had 4 at this point. I traded away the ZDP ones because I don't like ZDP189, but the F&F on both of the CF/ZDP knives I had was literally flawless. I gave one G10 Caly 3 as a Christmas gift and I kept and use the other one.
I didn't notice any variation in how the rivets are set on any of mine, but I did notice the blade marks from opening/closing the knife. I would prefer washers, personally. That's my only criticism of the Caly 3, and that's probably just my opinion. I've used mine everywhere from home to warehouse to camp sites and it's worked well in each setting.
Congrats on the III.
It's a small yet solid knife. About the $$$: With this knife, the quality will remain long after the price is forgotten. You are paying for full liners, G10, and premium steel. VG10 is better than 154CM, G10 is delux compaired to FRN.
Good review. I have a UK Pen Knife which is the same design, but with S30V, no lock, screw construction and a deeper choil. Having held a Caly 3 in a store I prefer that deeper choil. I agree with you on the ergonomics, there are very few knives, and most of them are Spydercos, that give me such a secure and comfortable grip that lends itself well to precise cutting. These days it's difficult for me to find another knife that I'd prefer to carry over my UKPK. The ergonomics are just that good, it's very light and thin, clipped to the pocket it takes up very little space so I can still easily get to my phone in the bottom of my pocket etc. One of the best knife designs I've ever come across in a folder for EDC.
Very good review. I have the CF/ZDP Caly 3 and have never handled the G-10/VG-10 version. The CF version feels pretty slick, but I bought mine for office and sheeple carry, so I never intended it for hard use. I also love the look of the CF and laminated blade.
I agree with gullwing, you're paying a premium for the materials used. You'll find that Benchmade doesn't have much of a choice for knives under $110 that use G-10. I also like VG-10 in general over most other folder steels. I have a 154cm bladed Emerson which gets very sharp, but I was able to get the VG-10 on my Endura sharper than any of my other knives, including my ZDP Caly 3 (just a little sharper).
Good review! I think this is one of the best designed folders on the market today. I agree that washers would be nice, but love this knife.
Looking at those pics, I'd say send it back! I really don't think those are the norm for the knife.
I sent an email to Spyderco about the possible defects on the knife, with the pictures above. Here's what I received:
"It's hard to tell from a picture what you are referring to. Two of the pictures I can see a flaw. I highly doubt that it left Spyderco with scratches on the blade. It's hard for us to be responsible for scratches on 2nd hand purchases. Regardless I can't determine it it would be covered under warranty without looking at it. You can try to send it back to the place you bought it from or you can send it to us for evaluation. Return instructions are on the back of the sleeve the knife can in."
I'm hoping some of the more avid Spyderco users can let me know if it's worth sending in, knowing they may not find it defective.
My Caly 3 did not have any of those flaws, aside from the scratching where the knife had been opened and closed due to the lack of washers.
I would be annoyed enough to send it in to the place i bought it from, at least.
The first time you cut a cardboard box you will scratch the blade.
If you let stuff like this bother you you are going to have a coronary.
For the kind of money you spent, I'd send it back, you should expect to put the first scratches on your knife when and if you wish to ... The flat grind looks a bit more than "off", more like off center big time.
NJ
Nice review with good observations.
Whether you worry about the scratches is, of course, up to you.
(But if it were mine, I wouldn't be worried about it.)
Eh. The scratches I'm not really too worried about, except that Spyderco is insistent that their knives don't leave the factory with scratches on the blade. That coupled with the back spacer marring, the uneven grind--it's a lot more apparent IRL than in the photo--and some of the scuffs on the G10 make me think this is one that slipped by Spyderco's quality control, or was handled by the eBay seller, even though he's insistent that that didn't happen.
I overnighted it back to Spyderco, I'm interested to see whether they will consider it outside their QC tolerances or not.
Either way, anyone who has read my posts on the forum knows just how much I can not shut up about my Mini Griptilian.
Well, I was really hesitant to put the Caly 3 back in its box, and ship it back to Spyderco. That's part of why I overnighted it, I'm hoping to be without it for as short a period as possible. I'm actually disappointed that I have to go back to carrying my Griptilian and be without the Caly 3, that's how much I like this knife!
Yeah... I really love my G10 Caly 3. Even though I usually EDC a small Sebbie, the Caly 3 just finds her way into the rotation pretty regularly. I'll pick up another one or two before the model closes out just for b/u. The Caly 3 and the Para-Millie are my fav Spydies.
The grind looks waaaaay off from the pictures you've provided. My ZDP Caly 3 didn't come with any of the issues that you've pointed out except for the scratches from opening and closing, which don't bother me.
I just got an email from Spyderco today. Apparently, aside from all the visual defects, there was a problem with the lock. They say it shouldn't have made it through quality control, and will be shipping back to me in a few days. I guess I'll have to edit the review to include info on a non-defective knife when it arrives!
Great news, I'm glad you're getting a new knife. The one coming should be a lot better and will most likely be representative of what most of us get when we buy Spydies.
