Just got mine. I've always liked the gray FRN CalyJr., but this is a nice 'upgrade'.
I've always liked how the finger choil fits my hand perfectly.
First impressions:
The frn handle is identical to the gray VG10 version of the CalyJr, but in burgundy. I am a huge fan of the color due to its uniqueness.
Standard black clip with a gold spyderco 'tick': Not crazy about the clip - too much contrast. The black looks strange against the burgundy handle and steel blade. I may replace it with the bead blasted gray clip from my gray caly. Tip down only L/R.
Lock is solid and smooth and identical to the VG10 version.
Blade labeled "Spyderco" "ZDP189/420J2". "Japan" on opposite side.
Another gold 'tick' is on the blade just forward of the opening hole, and I do like the placement of this one.
The lamination line is clearly seen on the blade about 3/16" on one side and 1/4" on the other, so the 'bread' in the sandwich is not there to protect the 'meat' from corrosion, but to support the harder steel.
On a knife this small, which will never chop, I don't see the need for the bread, but I don't see a reason to not include it either. I suppose it could make a difference near the pivot and lock if ZDP is prone to corrosion.
The edge is spyderco factory sharp, but no surpise there.
I have read that the ZDP is around 63Rc, so it should hold an edge for a very long time, assuming it is tough enough and wear-resistant at that hardness. The only issue with steel that hard is sharpening, but the blade is very thin and flat ground so I don't anticipate any problems.
Overall, it should out-perform the old Caly, and it is much better looking (i.e. less boring due to the color and the gold bugs).
When we get the chance to start really using these, it will be very interesting how the new (to most of us) steel performs.
EDIT: BTW, mine has ZERO blade play.
