The ZT 0900 is much larger than the Techno or Chubby. The 0900 has a blade that is 2.75". The other knives have blade much closer to2".
So that last post on the DPX HEAT really pisses me off at first. I already had three knives in mind then out of nowhere comes a new recommendation.
Two months later I pull the trigger on the DPX HEAT in CF shred instead of the spydercos and the ZT. I'm excited for its arrival.
Re; DPX HEAT in CF shred That's a fine looking knife! If your able to post pic's. go for it.
Haven't handled those two Spydercos, but I will say I like the 0900 a lot. It strikes a good balance between compact and beefy.
I have all three because I like "little big knives".
They may be roughly the same length (short) and roughly the same blade thickness (thick) but they're all fairly different from one another when you use them.
The Chubby is the fanciest looking IMO with it's carbon fiber in-laid Ti handle, and designer inspired pocket clip. It has a hollow ground blade that is all belly, giving it more cutting edge than you might expect for it's length. It makes a good utility knife. It can make very clean shallow cuts (it can have a very fine edge) but cannot slice thick items cleanly due to the thick hollow ground blade geometry. The construction is fantastic (like all Taichung folders) and the action is smooth and solid without ball bearings.
[/url][/IMG]![]()
The ZT 0900 is a tough little tank of a flipper. It has a good looking bowie blade and a nice stonewashed finish. It too does well with utility work. The blade has a nice flat area as well as a good belly. The grind combined with the blade thickness makes for a bit of a "wedge-like" shape. It does well when you need a sharp edge for a short cut or a sharp point. It handles most EDC tasks with typical ZT toughness. It does not slice well, but that shouldn't be any surprise. It pivots very smoothly and easily on ball bearings. The flipper on this one has a little more "horsepower" than most, and some will like it while others may not.
[/url][/IMG]![]()
I'll say right off, the Techno is my favorite of the group. I like the finish on the handle and the blade. The pivot is precise, smooth and solid. No ball bearings but it's just as smooth anyway. The overall construction is flawless. The blade is thick and short like the others but it also has a full flat grind that lets it slice a bit better than the other 2. It handles utility cutting and EDC tasks very well. The shape of the blade is about as non-threatening in public as a knife can be IMO. Since this one is my favorite little big knife, it goes with me every day in my left pocket as a money clip. Every other knife in my collection rotates through my right pocket, but the Techno is the only knife that is truly with me every day.
[/url][/IMG]![]()
