you do have to sharpen both sides
Reading from the same manual, Serrated edge-alternate single bevel, similar to above instructions but 3 strokes on the serration side to 1 on the other side, a 3 to 1 ratio. According to the book this method will create a sharper but ultimately weaker serrated edge, sharpening on both sides alternately will create a straighter cut and a stronger edge, quoted from the book. So it looks like the best way is to alternate strokes, using only the corner of the stone. Sorry for the confusion and thanks for clearing things up.ok, im reading straight from my spyderco sharpmaker instruction manual and this is a quote " serrated or scalloped edge knives" "done in the same manner as sharpening a straight edge knife but only use the corners of the stones (step #1 and step #3) in most cases step #1 wiil not be necessary and step #3 will be sufficient. the corners of stones will slide in and out of the serrations. SHARPEN ON BOTH SIDES even if original sharpening is only on one side. this will create a straighter cut when using the serrated knife." unquote. i hope this clears up any doubt that i was correct in my advice in how to sharpen your knife.,,,VWB.
