- Jan 3, 2003
I received the passaround Spydie D'Allara with the good graces of DaveH and Spydies Sal G, Thank you guys.
The specs are at the bottom.
First thought when I opened the box:
WOW!! This sucker's big!!
It is quite a handful.
The handle fit me very well, was quite comfortable and is definitely non-slip!
I flicked it open with the usual Spydie ease.
I liked the fit and feel of the D'Allara in my hand. A very substantial Rescue knife.
The unique, to me, aspect of the knife is the ball bearing lockup. It took a very little to get used to in order to close one handed. Not bad at all.
Impressive lockup to be sure. No play anywhere. A solid piece in the hand.
I did exert a lot of lateral force to see if I could bend or move the blade. Nada...solid as a fixed blade.
The blade ia a massive hunk of beautiful steel.
I've gotten away from an appreciation of serrated blades and this sucker is serrated all the way
I would REALLY, Really like this knife if the blade was pe.....sigh
The handle has the deepest, grippiest cuts of any handle I've ever seen.
I didn't like this at all.
I always wondered at some threads where the guy says that the pants would fray or wear with the knife clipped. I thought they were exaggerating in the Knife Knut way.
Not so with this handle. It'll wear a pocket down to ribbons in no time. I had several occasions when I thought I had pushed the knife all the way down in my pocket. But I was wrong. It was getting hung up on the traction grooves.
I didn't like the clip placement when I held the D'Allara for heavy carpet cutting.
I would sand the grips and remove the clip if it were mine.
I probably would have no problem with the knife sliding into the phone pocket of my Royal Robbins 511 pants.
It would also have a Plain Edge.
To be fair this knife is designed for Real world heavy rescue. It looks to be able to pry, cut thru metal. Everything a rescue worker needs to do.
The knife can handle most any rescue need I could imagine. It's that nice if it were pe.
I hope some of you fire, police, rescue folk would pipe up if the serrated is very important to your rescue work.
Here are a couple of shots in my hand.
Did I really have to explain that????
The specs
Spyderco D'Allara Rescue
A new rescue model, featuring Spyderco's Ball-bearing Lock System. The handle is black FRN backed by full steel liners and backspacer, for a hefty and solid feel. A reinforced wire pocket clip screws onto either side for both left and right-handers.
Specs
Blade Steel: VG-10
Blade Thickness: 1/8" 3mm
Clip: Heavy-duty wire clip
Diam. Blade Hole: 9/16" 14mm
Edge Type: Full Serration
Handle Material: Fiberglass Reinforced Nylon
Hardness: 59-60
Length Blade: 3 3/16"
Length Closed: 5"
Length Overall: 8"
Thanks again Spyderco for the opportunity to handle this well made USER in real world situations.
And DaveH too
The specs
Specs
Blade Steel: VG-10
Hardness: 59-60
Length Closed: 5"
Length Overall: 8"
And DaveH too
