I'm looking to get a modern folder to alternate in my EDC. I typically carry a traditional slipjoint and want to give some super modern knife a try.
Criteria:
Some fancy super steel that holds an edge well
Cannot look too cheap or "tactical"
Can't be something that would scare citizens (assist opening is out)
Should look modern
Blade should be no bigger than 3 inches
Around $150
I want something that's a nice cutter that will hold it's edge. Edge holding is the main criteria I'm looking for in the steel. I treat my knives like knives so it won't be a pry bar, it won't be used to stab through a car door, it won't be batoning firewood. It won't have to get me home if the zombie apocalypse hits while I'm at work. It will be used to cut some cardboard on occasion, cut stray threads, open plastic clam-shell containers, and perhaps cut fruit. Yes, that's not much of a demand on any steel, but since I'm giving the modern knife a try, I figure I might as well go for fancy steel. (I've got a Dozier that I've had for a while in D2 and it seems nearly impossible to dull with my typical usage.)
Given these goals, the Spyderco Gayle Bradley and the Benchmade Shoki 480-1 have made my short list.
The Sypderco has CMP M4 steel with glass fiber scales. The Benchmade has M390 steel and carbon fiber scales. I've not owned any Benchmade so that puts a bonus point in the BM column. I don't think I can go wrong with either.
Any other options I should consider before I pull the trigger?
Criteria:
Should look modern
Around $150
