h1 is ok but i found out that it does best with a coarse edge. i put an 80 grit edge on an h1 salt for a member and it would shave hair and will probably hold the edge a lot better than a finer edge.
jimnolimit said:Good to know. I have an aqua salt coming this week, I'll try the edge at 250 grit, 800 grit and 4000 grit to see if I also notice the difference.
Unless you buy a custom sheath that doesn't have the issue I mention above, don't bother. Seriously, you can see the edge damage after removing/inserting the knife into the sheath 2-3 times.
thats why spyderco can't do FFG h1, it gets too hard and wears out belts.
jimnolimit, i would start out coarser than 250 but first i would give the factory edge a try first and see how it holds up. the one i was sent was in need of sharpening and had a somewhat fine edge so i went coarser and then finished the edge off with the slotted paper wheel.
