First of all, I would like to thank Dave H. for this pass around of his personal Lil Temperance.
DETAILS Details can be seen on Spydercos site -
http://www.spyderco.com/online_prod...=C69&mscssid=XW8T783FQUTJ8NWHUGQ5W3EUJWRW55V1
Daves Lil Temperance has the modified spear point/ leaf blade.
OUT OF THE BOX Wow this thing is ugly! Everything about the Lil Temperance seems substantial and rugged. The Lil Temperance was comfortable to hold and opened smooth and fast; although like the ATR, closing took a little getting used to due to the position of the lock on top of the handle (opposite of a liner lock).
QC of the Lil Temperance seems very good although, as other reviewers have noted, the pass around knife dose have some blade play. Also one of the recesses in the g-10 scales for the pocket clip had a sliver of material around the pivot that was not fully milled out.
LOCK The Lil Temperance has a Compression Lock, which has some similarity to a liner lock except that it locks between the top of the blade and a stop pin. The Compression lock seems to be very strong and stable. The Lil Temperances compression lock seems to be near impossible to disengage accidentally in any normal grip.
BLADE The 3 blade is the modified spear point which I would describe as a form of drop point (there is also an upswept modified Bowie which I would call a trailing point variation).
The blade is fairly thick; starting out at .157 on the spine just forward of the handle scales and tapering to about 0.045 at the tip. The blade is about 0.026 behind the edge.
STEEL This Lil Temperances blade steel is 440V (S60V). Spyderco is in the process of phasing out 440V in this model in favor of S30V, another Crucible particle metallurgy steel. There is some information from Sal Glesser and others on S30V and 440V in this thread -
http://www.bladeforums.com/forums/showthread.php?s=&threadid=270056
HANDLES - The Lil Temperances green G-10 scales fit my hand well in all grips. The integral guard and thumb ramp separate the hand form the blade and the two rear finger grooves give added grip security. While secure, comfortable, and certainly hand filling, the Lil Temperances grip is fairly bulky and thick (.525 across the scales, .735 including the clip).
LINERS The Lil Temperance has dual nested steel liners.
POCKET CLIP - The Lil Temperances wide plain steel clip is similar to the ATRs clip. The Lil Temperances clip can be switched from tip up to tip down carry, but is not reversible to the left side. While the Lil Temperances clip is similar to the ATRs it is a little looser, so it was not too tight on my Wrangler jeans pockets.
The Lil Temperance is kind of bulky for its blade length but it carries well clipped.
CUTTING PERFORMANCE I used the Lil Temperance for basically the same things that I used the ATR for and I really appreciated the Lil Temperances full flat grind on deep slices, but the blade is a bit too thick in my opinion and could use a little more belly.
EDGE HOLDING & SHARPENING - The Lil Temperances 440V blade seemed to hold an edge very well but not quite as well as the S30V ATR that I was testing at the same time.
440V has a reputation for being a bear to sharpen and I am sure it could be if a lot of metal needed to be removed, but the Lil Temperance (having been previously properly sharpened) was a breeze to touch up using a DMT hone.
CUT TO THE CHASE The Lil Temperance is a rugged utilitarian EDC with a defensive slant. I like the Lil Temperances ergonomics and the blade shape, although I would prefer a thinner blade with a bit more belly.
Thanks again to Dave H. for the Lil Temperance pass around.
- Frank
Here are some links to some other pass around Spyderco reviews -
Temperance (FB05) & Impala (C73)
http://www.bladeforums.com/forums/showthread.php?s=&threadid=263754
Native Lightweight C41BK
http://www.bladeforums.com/forums/showthread.php?s=&threadid=268455
A.T.R C70
http://www.bladeforums.com/forums/showthread.php?s=&threadid=270638
Chinook II C63GPS
http://www.bladeforums.com/forums/showthread.php?t=293968
Jester & Ladybug with Photons
http://www.bladeforums.com/forums/showthread.php?p=2499036#post2499036
- Frank
A.T.R C70
Chinook II C63GPS
