I just got this Friday and its very nice . Do you think I should use it or put it away ? Its not numberd but I think spyderco is only making 500 of them . Wish they would make a full production run of them in the carpenter steel.
CTS-XHP will never replace S30V. The high hardness and toughness seem pretty good, but the thing doesn't have enough carbides in it to be worth half a damn in terms of wear resistance. You hear a lot of things about the steel, but wear resistance is not one of them.This is first production knife with CTS-XHP steel. I expect this steel to substitute CPM S30V which is now confirmed by recently leaked out CATRA test results to be pretty average way behind CPM S60V which it replaced 7-8 years ago. So I guess Crusible era which actually ended once they stop producing CPM S60V (and for so many years and after so many attempts can not make anything better), are gone for sure now.
I am not sure if it will be any collection value - does not look that any body care about first production ZDP189 knives. I also think that every knife manufacturer will start using this steel and so it will not be exotic any more.
I am using my Manix 2 from first run and really pleased with it - it does not only show excellent test results, but really works longer then other knives. I used to cut tooling leather, and woodworks.
Thanks, Vassili
I would however expect it to replace 154CM as a premium steel.
As far as my Manix 2 goes, it seems like a decent user knife. Not hard use, but great for light to medium EDC cutting. Trimming one or two cases of corn alone seems to rapidly degrade the edge from hair whittling to the point where it tears paper instead of slicing it. Corrosion resistance seems pretty good.
