Spyderco Manix
Cliff Stamp
BANNED
The Manix is a large heavy duty lock back from Spyderco with a similar build to the Chinook II which I posted about awhile back. The Manix has a higher indexed handle which locks into the grip more but is slightly less versatile than the grip on the Chinook II for the same reason. I prefer grips like the Chinook II, but the index finger cutout/notch on the Manix isn't so prominent that it prevents working with reverse grips and so forth.
The Manix came Spyderco sharp, well above shaving, with an edge which is acute enough to able to be touched up on the 15 degree setting on the Sharpmaker. With the high flat grind and efficient edge profile, the Manix cuts very well, with a complete sharpening profile showing a polish able to efficiently push cut hemp, while still showing enough aggression on the draw to reduce the force by 50%.
The point is very slim and the blade has a fine taper so the tip has excellent penetration with both light force and heavy stabs. On an side note, the tip penetration on some of the stock work was about 10% lower than on the Temperance, I had actually thought the blade profiles were almost identical so I hauled out the Temperance, it actually has a slightly narrower profile through the tip, the Manix has a wider tip through a greater curvature.
I was carrying this alongside the Paramilitary for a few days and it quickly became obvious as to when the Manix stood out. Both blades have similar blade profiles and edge grinds and identical steels so they cut well and have similar durability, edge retention and ease of sharpening. The main difference is that the Manix has a much larger handle and wider blade and thus tends to work better for heavy cutting with a lot of force.
Use both knives to trim vegetables, work on small sections of meats ans similar and the Paramilitary is easier to manipulate, both in regards to the handle and turning the more narrow blade in the material. However in roughing out wood, cutting really thick ropes, or heavy cardboard where a lot of force is being used, the larger and more grip filling handle on the Manix is more comfortable.
The Manix also has a stronger blade for prying, but S30V will not flex significantly before it breaks so heavy prying with either isn't a good idea unless the force is constrained across the main body of the blade, i.e. get the blade way in the material past the point.
More details on the geometry, stock cutting tests and so on are in the review on the website, still in progress. I will be taking this one apart like the Chinook II, a little more controlled this time as last time I just wanted to know if the blade would go before the lock, and how the lock would behave when it started to get damaged. I will also run some edge retention comparisons vs VG-10 as both are high end stainless and I have a few blades in both.
One note about sharpening, one of the first S30V blade I seriously sharpened gave me a horrible perspective on the steel in regards to machinability. Problem was I had been sharpening 52100 and similar for weeks, doing a lot of comparative cutting and S30V is many times over more difficult to grind. With steels like these you really want to start out with a x-coarse hone if there is any visible damage. I use a SiC waterstone and check to make sure the grind goes right to the edge before ramping up to a higher grit stone.
Of course if you are just applying a secondary edge bevel there is no problem, it takes a crisp edge then in just a few passes, assuming of course the primary edge grind is acute enough, check that with a marker as Joe describes in the FAQ.
-Cliff
Thank you, Cliff! A good review and account of your experiences with this awesome knife. :)
It is a very solid knife, I will be having my brother carry this and used mainly during his work (construction), while I carry out some edge retention work I have put off for awhile.
-Cliff
I was considering the Manix or the Military.
I might go with the Manix because I tend to favor Lockbacks since I might trigger the linerlock with my bear paws. :D
Anyone know if the acutual strenght is indeed stronger on the Manix Lockback than the Military Linerlock?
I will probably give the Manix a try regardless.
Only other folder I was considering is the SOG X-Ray Vission but its in ATS-34.
Appreciate your input guys.
I don't think there is any comparison between the two lock strengths between the Military and the Manix. I'd put my money on the Manix everytime for sure.
Correct me if I'm wrong, but the Manix is MBC rated, where the Military is not. That should be a clear indication that the Manix has the stronger lock, in terms of Spyderco's testing procedures.
Not that I'm busting on the Millie. The Millie is my favorite folder. It's just that the Manix is an absolute TANK!!!!
Outside of hitting the spine with a baton with heavy force, actually exceeding the strength of the Military's lock isn't a practical concern. The big problem is with white knuckling and torques, these are both very critical to both the specific lock and user, so be careful to test it out fully in a variety of grips and do some torquing if you intend to use the knife in such a manner.
-Cliff
Great review!
Hope you get a chance to have Phil Wilson redo the blade on your Manix (mine still needs such TLC) so it's already stellar performance may be enhanced (a wee, but very important amount :) ).
SpEcTeR said:
What is it he does for the Manix? I'm seriously considering one now.
:cool:
Thom has him (Wilson) heat treat the blade to bring it up to a higher Rockwell hardness, with great results I hear. Get the Manix, you won't regret it! :cool:
On some of his knives, Phil runs his steels very hard, harder than most other custom knifemakers even. His hunting, light utility, and fillet knives are very hard, around max quench hardness. Generally, his kitchen knives and large bowies are not as hard as they are adjusted to find an optimal balance of toughness and edge retention. This is all his personal perspective on performance of course, if you want him to make a ful hard kitchen knife, that's fine, he has made some very high end pieces in S90V.
-Cliff
Cliff,
I'd dearly love to see a comparison between the Manix and the Swamp Rat Rat Trap folder. I've had these two knives in my mind for quite a long time.
I'd love to see a side-by-side comparison from an objective source.
There is such a comparison online, but it's in Russian and that's outside my language skills at the moment.
When the opportunity arises, you've got at least one fan waiting for your input.
Thanks,
Tom.
Bali Fly said:
Cliff,
See how many good reports are online from each knife. See how often you find one on the private selling board. I guess, very good knifes are those to keep. The not as good are the ones to sell.
Cliff,
You used the Chinook II as a comparison/reference point for your review of the Manix. Could you do something similar with the Manix and the Ritter Grip? I would be very interested in a comparison of the Manix and Ritter Grip blades in terms of utility and efectiveness of design. Also the effect the blades thickness in the overall abuse the knifes can take.
I'm sorry if this is thread hijacking, but it would give me a better picture of the Manix and answer a few questions I have on how the Manix and the Ritter Grip compare. I know there are several threads on the Manix and the Ritter Grip, but I haven't seen these issues addressed in those threads.
I'll compare the Manix to the Rat Trap once the guys currently using both are finished with them, minimal weeks away. These are two pretty different knives though, the Rat Trap compares more directly to the Spyderco Military as a similar design which I also have in S30V and will note in the reviews. I don't have a Ritter Grip. There are a number of Grips not Ritter, on sale on Ebay now for low prices so I might pick a couple of them up as I have been curious about the Axis lock for awhile.
-Cliff
I have Cliff's Rat Trap. Feel free to send me nastygrams if I don't get it back to him ASAP :) Cliff, I'll try to send it off this week, with my impressions.
Joe
