Ankerson
Knife and Computer Geek
- Nov 2, 2002
This is a performance review tested in cutting rope, cardboard and wood. The knife was sharpened to 30 degress inclusive with the 400 grit Congress Sil Carbide stone then stropped on my Sil Carbide loaded strop. This gives the best overall edge balance for edge retention and cutting efficiency from my testing. The Congress stone can be substituted with the 600 Grit EP stone or a Fine Grit Norton Sil Carbide Stone as long as the edge is stropped on Sil Carbide after.
The knife was sharpened as laid out above and the edge wasn't touched up durning the testing process at all.
The Process:
Rope - Made 90 slicing cuts on 5/8" Manila rope.
Cardboard - Cut up the cardboard shown in the photos below.
Wood - Whittled wood taking thin and thick slices to check edge stability.
Rope:
Cardboard:
Wood:
Conclusion:
CTS-XHP performed very well, it develops a toothy edge very quickly and stays sharp enough to continue to cut for a very long time. It's comparable to ZDP-189 in the way the edge transformed into that toothy working edge. After all the testing the blade would still slice through printer paper easy. I do think that the hardness could be bumped up slightly to make the edge stronger as it did get a few flat spots during the process.
The Process:
Rope:
Cardboard:
Wood:
Conclusion:
