Where do you get that from?!?
Very cool, I have the M4 MULE. Can someone list the different steels used in the MULE line.
How can you have a damascus blade but a (seemingly) non-damascus tang/handle?
52100, CPM-M4, S90V, ZDP-189, 9Cr18Mo, S35VN, CTS-BD1. I think that's all so far.
Think of it as San Mai but with the outer layer being damascus. The outer layer is damascus and the inter core is VG-10. The cutting edge is going to be VG-10 instead of damascus like in a 'real' damascus blade. When damascus is the cutting edge there is a change in performance since there are different alloys that erode at different rates along the cutting edge. This produces a micro serration effect since different alloys make almost a fine saw tooth effect.
In this sense this is not a true damascus blade as the cutting edge is 'only' VG-10, but there is 'real' damascus in the knife, however, it is just for looks and on the side of the blade where it won't become part of the cutting edge. This knife should perform roughly the same as a solid VG-10 blade. The only difference may be how the damascus cladding moves through the cutting medium. It might be a little more rough when cutting things, or some sticky materials like cheese might not stick quite as much (think micro scallops like on a typical Santoku).
It is not real Damascus, though.
From the Spyderco site: "... The Damascus Mules steel is composed of layers of erosive and non-erosive material over a VG-10 core center. The erosive layers are hard martensite stainless steel and the non-erosive layers are anti-corrosion nonferrous metal. These layers block carbon particles in the core from spreading to the outer layers. After layering the blade is forged to intentionally distort the layer-lines making a complicated, artistically beautiful pattern called Suminagashi. Suminagashi is the traditional Japanese art form of creating ripples of Chinese ink on the surface of water. This steel mimics the art form with interesting results on a knife blade..."
The Damascus serving only a purely decorative purpose, it is not a Mule, either (To me a Mule is a no-nonsense knife meant to test different steels. Maybe the concept has evolved...).
