- Dec 8, 2012
So I got a used spyderco navaja today. Is there no detent to the knife? I can swing my knife open like a gravity knife.
I've never had this problem with my navaja. Try tightening the pivot, should fix it.
Tiguy: The carraca mechanism has no practical effect. I actually took it out of mine due to the noise attracting too many looks.
And there DOES look to be a detent ball on the liner, so I'd take a look there, it's easy to see. You can see it by looking under the bolster when the knife is open and the lock in engaged. If you don't have it, I'd advise sending it to Spyderco or asking for an exchange from wherever you got it.
To the OP: I hope this works out, if you'd like, I can try to get pics of the detent ball on mine for comparison.
The detent ball is staked into the leaf spring and drops into a dimple in the blade (to hold the blade closed). I don't think this would be an easy repair. You would have to make hole in the leaf spring large enough to accomodate about 2/3 of the ball and then be able to upset the material around the socket enough to retain the ball.
Send the knife in
