Spyderco Navigator II C93
SOLD Pending Funds
A really nice user. Excellent lock-up and fit. Once part of my EDC rotation. Handles got a little scratched-up by keys in pocket so I ran some Scotchbrite over them and they look good again (a brushed stainless look). Polished blade used very little and only touched-up on a Sharpmaker with fine grade ceramic stone. No box.
Discontinued, no longer available from Spyderco
From Spyderco: The C93 Navigator II focuses on three features found in larger, hard-use pocketknives: A strong lock, robust blade and ergonomically advanced handle. Combined, these features convey the tactile sensation and performance features of a full-sized knife packing significant cutting power yet the Navigator II’s blade is just 2-1/4” long. Made from VG-10 stainless the blade is available SpyderEdged or PlainEdged. Its cutting edge is saber-ground on both sides of the blade for superior cutting capacity. Positioned above the Spyderco Round Hole a spine cusp forms a stable leveraging point on which the thumb rests. On the underside of the all-steel handle are a series of sculpted angles cut away to optimally settle the hand and fingers into grip position. The pocket clip carries the folder tip-down or can be used unobtrusively as a money-clip or tie tack.
length overall 5 7/16" (138 mm) blade length 2 1/4" (57 mm) blade steel VG-10 length closed 3 1/4" (83 mm) cutting edge 1 15/16" (49 mm) weight 2.7 oz (76 g) hole diameter 15/32" (12 mm) blade thickness 3/32" (2.5 mm) handle material Stainless Steel
Shipping CONUS included (can't do overseas). $40 Paypal or USPS MO.
First "I'll take it" in this thread gets it. Please ask questions before purchasing.
By purchasing this knife you are stating that you are 18 years of age or older and are complying with the laws in your area.
If your Navigator II is PE, I'll take it. Please email me your info so that I can send you a M/O. I'm at: cockedlocked01 at yahoo dot com
Thanks.
In Spyderco language I know that "PE" refers to "Plain Edge". If that is the question then yes, as the attached pics show, it IS a plain edge. OK?
