- Mar 4, 2019
Hey guys I'm wondering what knife I should get the Spyderco para 2 or the ZT 0393 hinderer?
Yes this is perfect thank youM Moonknight314 welcome to the forums. It is a great place to get a lot of information. I will give you my thoughts but before I do I will preface it with the fact I am a dealer and a big fan of ZT.
The question you ask is tough to give a direct answer to. While the 2 knives are pretty similar in size, their intent of typical use is a little different. The ZT0393 is much more overbuilt with a lot more steel behind the edge. It will not be the best slicing knife out there, so if your intent is to slice an apple, slice up boxes or just have a wicked sharp slicing knife... the ZT0393 is not for you. While the ZT will certainly do all of these task it will not do them with the precision and capability of the PM 2. The PM 2 is thinner stock, ground thinner, and has a much finer tip. Slicing, precision cuts and your daily cutting task are going to be easier and much more slicer friendly. With the extra slice ability of the Spderco you lose the overbuilt tip and blade stock of the ZT0393. If you are rough on a knife or plan to be, especially the tip, I would go 393. If not then it really comes down to which task you are going to do the most. Both will do decent at all task you mentioned, but each excel in different areas. Hope this helps!
Yes, this is perfect thank you.M Moonknight314 welcome to the forums. It is a great place to get a lot of information. I will give you my thoughts but before I do I will preface it with the fact I am a dealer and a big fan of ZT.
