Spyderco has been doing a slow CQI on the Manix 2 adding a Ceramic Ball bearing for the main lock. The Salt Paramilitary 2 has ceramic detent as well for rust resistance. Most high end folders use ceramic over steel stock as it’s harder material which resists deformation better. Over time with multiple blade cycles the steel will wear and get a flat spot. Especially knives without ball ramp on blade. I also like to tinker with my users adjusting lock bar, add better bearings if equipped, Polish washers, add detent ramp, smooth scales, etc! The ball is press fit and easily changed.Forgive my ignorance but are the ceramic detent balls somehow better than the standard ones?
Is the new detent ball held in place by the Loctite?
You’ll notice a difference if your knife has a worn deformed detent ball….usually takes a while. The bearings in picture are for a ZT and Hinderer! I’ve changed to skiff bearings on Domino, Amalgam, And Smock with fantastic results.I was wondering the same thing? Do you actually notice a difference? Also, bearings in the pic, you didn't put bearings on a para 3 did you?
Thanks very much. I appreciate knowing this. I’ve been flicking my Para 3 open a lot since I got it for both practice and for fun.Spyderco has been doing a slow CQI on the Manix 2 adding a Ceramic Ball bearing for the main lock. The Salt Paramilitary 2 has ceramic detent as well for rust resistance. Most high end folders use ceramic over steel stock as it’s harder material which resists deformation better. Over time with multiple blade cycles the steel will wear and get a flat spot. Especially knives without ball ramp on blade. I also like to tinker with my users adjusting lock bar, add better bearings if equipped, Polish washers, add detent ramp, smooth scales, etc! The ball is press fit and easily changed.
How exactly do you go about removing the ball?Took 10 minutes and they fit perfectly
Got around to the OG Military today and the 2mm ceramic ball fit perfectly! My phone had a hard time focusing but you can see a small flat spot had formed on the original steel detent. Interesting that this knife had less pocket time than the above Para 3 and the ball had more wear!
Interesting indeed. I don’t like to tinker with my knives because more often than not, I will mess something up. Sometimes I take the chance and come out glad that I did. Other times, not so much.View attachment 2770904View attachment 2770905View attachment 2770906View attachment 2770907 Interesting that this knife had less pocket time than the above Para 3 and the ball had more wear!
I’ve never had a knife wear a detent ball to the point where I could tell. I’m assuming the opening would become gritty and blade would shake open easily. That being said, I’ve adjusted the “detent” strength on Taichung models( Caribbean, GB2, Smock, etc) by slightly enlarging the hole on the blade. The OG military probably had more deformation than the Para 3 from lack of detent ball ramp and more lock bar tension.What exactly happens when the detent ball wears a flat spot? Does the detent become weaker or perhaps inoperative?
Thanks very much!I’ve never had a knife wear a detent ball to the point where I could tell. I’m assuming the opening would become gritty and blade would shake open easily. That being said, I’ve adjusted the “detent” strength on Taichung models( Caribbean, GB2, Smock, etc) by slightly enlarging the hole on the blade. The OG military probably had more deformation than the Para 3 from lack of detent ball ramp and more lock bar tension.
I like to mess with my users so I’m embarking on this project to change to ceramic, but if it was a systemic problem with Spyderco knives you’d hear more about it. Of course Spyderco is doing a rolling change to ceramic on some of their products…so who knows!
