Or adjust the tension between the clip and the scales by bending it out a hair, like I did, with a brand-new Paramilitary 2 this morning ironically enough. If it gets bent out too much a T6 Torx bit fits the screws, take it off and bend it back in a hair.
Problem solved, and the scales remain pristine in case you want to switch the clip to the other side sometime later.
You won't have scales sanded down in the middle only on one side and looking weird. Try to sell it that way (if you have to) and you'll lose more money than you need to if you starting sanding on it, and that cannot be undone.
Relieving some tension on the clip can be. Screw it up, and Spyderco will send you a new one for free.
