Perfect for edc. The S30V is stainless, so you're gonna get plenty corrosion resistance. I think it is strong, I guess you could say rugged...zero blade play and solidly constructed. It is often considered a "hard use" knife, but to paraphrase another poster I saw recently, I don't understand why they put such a fine tip/point on a "hard use" knife. I would consider it to be a strong and rugged slicer, but I'm not sure I'd be comfortable really whacking on the blade like a fixed blade knife.
The compression lock is a bit awkward but usable. I'd prefer a liner lock like the full size Military. The blade edge is a bit more curved than I'd like, but I haven't really had a problem in use. The clip makes the knife ride a bit higher in the pocket than I'd like as well, but I got used to that quickly. It doesn't flop around in-pocket like I thought it would since the clip is so secure.
If it literally is the "perfect" size, and you've already considered what I've discussed here (lock, blade shape, clip, etc.), you can't go wrong. If you haven't thought about these things, specifically the lock, you may want to check out the bigger Military for just about the same price. I find the size of the Military carries fine, but I'm about 6'2" and 250#, so YMMV.
