Have a look at the Spyderco section of the forums. There is a lot of discussion on this already.
Yea I seen it after the fact but rather the thread be moved rather than create another one.Spyderco forum is here, http://www.bladeforums.com/forums/forumdisplay.php/726-Spyderco
I get much better results finding certain topics by using yahoo or google search engines and just typing something like "Paramilitary 2 bladeforums" or Paramilitary 2 hype bladeforums something like that and you will have much better luck that the search engine on this site.
To answer your first question, it takes a lot of the features people love in the Military and shrinks it down into a more compact, EDC-able package.
It's just a very well designed knife that feels great in hand.
The PM2 is a very unique knife. The handle, blade, and lock are all very usable designs that result in a package that performs very well regardless of what you need it for.
I do think the PM2 is either a love or hate knife that one has to actually use a little while to decide where they stand, and I fall into the love category.
There isn't any knife in the Spyderco lineup or any lineup that really compares. At $50, a used Endura is probably going to be the best Spyderco option. While the Endura and PM2 are both awesome knives, their styling and designs are about as polar opposite as they came. For that matter, the PM2 is such a non-traditional design that it is difficult to compare it to other knives.
The handles on both the PM2 and Military are elongated for better grip options and control. Both are designed to flow with the positions of your hand. For instance, if you have a forward grip on the handle with your thumb on the jimping behind the opening hole, the blade follows the line of your thumb. Also, the Compression Lock is just about the easiest lock to operate in the Spyderco stable. The PM2 has standoffs rather than a backspacer, so it is easier to clean. It has a very aggressive point that is great for piercing, especially when you need to start a cut.Yea I seen it after the fact but rather the thread be moved rather than create another one.
I searched this forum and google, but I mostly seen "vs" threads. I was hoping to find out what the most popular and exclusive features (compared to all other under $100 Spyercos) were most popular, and if there were anything that was closely comparable.
Okay the handles, blade, and lock are usable. How so? How is it different than their other knives? Other Spyderco's G-10 handle, similarly shaped blades, and ambidextrous clip positions... The only thing I can think of is the Compression Lock. Other than the geometry of the blade and handle, is the only ther difference/feature is the Compression Lock? Like in other threads I've seen, people would simple give generic responses saying that the Paramilitary's <insert here> is "just" better without explaining how so...
thanksThe handles on both the PM2 and Military are elongated for better grip options and control. Both are designed to flow with the positions of your hand. For instance, if you have a forward grip on the handle with your thumb on the jimping behind the opening hole, the blade follows the line of your thumb. Also, the Compression Lock is just about the easiest lock to operate in the Spyderco stable. The PM2 has standoffs rather than a backspacer, so it is easier to clean. It has a very aggressive point that is great for piercing, especially when you need to start a cut.
Basically the PM2 takes a lot of the best features found in different Spyderco knives and combines them. The nearest competition would probably be the Manix 2, Military, and Gayle Bradley. Manix 2 caged ball lock is a pain to use compared to the Compression Lock, Military is a larger knife/handle and is either liner lock or frame lock. Gayle Bradley is a liner lock and a hollow grind which some may not like, even though it does have the high end M4 steel.
It emphasizes form over function, so if you actually use your knife you will really begin to appreciate it.
