It's a great knife. Much more utilitarian than it looks. The blade shape is excellent for slicing and the fine tip is neat. Scares the hell out of some people though.
The handle scales and edge hold up well. Can't say the same for the blade alignment. It started to rub against the inner liner on opening after about 4 months of use. That was about 2 years ago. I believe I tightened all the screws that hold the frame together, adjusted the eccentric pivot (if it has one, I don't remember), backed out the pivot pin, put on lock-tite and screwed it in until it was just tight enough to hold the blade in the middle between the liners, but not so tight that it was hard to open. Did that about 18 months ago and haven't had a problem since. I've also had to do similar things to my Starmate and Lum Chinese for the same problem.
