Spyderco Sharpmaker and Leatherman Micra
First way to try is to place a rod in the scissor position like you normally would. Corner up seems to work best. Then open your Micra scissors and rotate the handles to the right (assumes the rod is to your right from the base) until you can lay the edge on the flat part of the rod (the side away from you). Takes a little bit of fiddling to get the angle right, but doable.
The second way is to just free hand the angle with the Micra in one hand and the rod in the other. Use the rod like a file.
If you can't get a mental picture of how this works let me know and I'll try to grab some pics at work tonite and post them as a better explanation.
