Anecdotally I've read that the SM diamond rods are sort of "slow" for diamonds and are considered kind of a "medium" grit on the diamond scale. I've also read that with heavy pressure the diamonds scrape off, which is true of all diamond systems that I'm aware of. They'll certainly be way faster than the medium ceramic the SM comes with.
If I *had* to do it all with the SM, I'd either buy wet/dry sandpaper in various grits and wrap/clip it to the SM stones. Or perhaps I'd get some of the Congress Tools ruby stones (aluminum oxide). They (CT) make triangle shaped stones that fit the SM perfectly and work WAY faster than the stock rods/stones. Do a search here and you should find a lot of info about them.
Good luck.
Brian.
