First off and foremost - I can not free hand on bench stones very well. It's a talent that I currently don't have the time to learn. The other reason why normal benchstone freehanding wasn't used is because I don't have a stone that is 1/2" or so, and this knife has a small recurve to it. Normal benchstones, 1" and larger, simply won't sharpen part of the curve. In addition, DO NOT PUSH DOWN. You only need 1-3 pounds of pressure to sharpen. Any more than that and your'e wearing out your hone, especially if it's diamond or a water stone. The finer the grit, the less pressure is needed. Now, onto my impromptue guide.
For equipment, you'll need, at a minimum, some sort of hones (commonly refered to as sharpening stones). Medium grit if you have to choose only one - it won't cut the fastest, but it'll still let you get a very nice end result. Use water, not oil, for lube on the stones, if the manufacturer recommends lubricant of some kind. Why? Because water's dirt cheap, does the same thing, is available everywhere, and if you use oil even once, it's a pain to go back to water. Just trust me. Make sure to clean your stones with some powdered Ajax or similar cleaner with a cleaning pad like an SOS pad when you're done to remove the steel from the stone. I'm currently using a Spyderco Sharpmaker. I do not have the diamond or ultra fine stones for it at the moment - added bonus - they're meant to be used dry, so no water or oils involved. A sharpie. Optional: a stop, and some rubbing compound. Pretty basic strops can be made from the back of a legal pad and some rubbing compound. My equipment for today:
Can also be used for scissors
or as a bench stone
or as a bench stone
