Spyderco Sharpmaker
Wow, I'm almost totally clueless about those. For the past couple years I've been listening to people about how cool those sharpmakers are. I've never used one before. Anyone want to tell me about it? So far I'm confused as to the differences between the 203 and 204 (why is the 204 more expensive). How polished of an edge does it give (compared to the average factory edge). I like my knives to look nice. How well does it work on the serrated edges?
-Chang the Asian Janitorial Apparatus
Same question here???
I'm just getting into knives and I'm trying to find a good sharpening system. I hear alot about the Sharpmaker and would buy one if I thought I could make it work. I bought a Gatco "Tri-cepts" ceramic just to try. I've only made the edge on my BM730 worse with that thing.
I need something "stupid proof"! Is the Sharpmaker "easy" to use?? How about the Lansky system with the "hone-on-a-rod" and "angle guide"?? How about this sytem by Razor Edge....
Which system is eisiest to learn on and most effective?? I know it must take some time to learn on any system, but man! I really must need something simple!
Repeat after me...
"Gottahava730"..."Gottahava730"...."Gottahava730"!
The Sharpmaker really is as easy as everyone says. I just got one 2 weeks ago and within 1-1 1/2 hours I was sharpening everything shaving sharp. I was not able to sharpen anything before I got the sharpmaker, now every edged tool in my house is razor sharp.
Eric
If you can hold a knife, you can sharpen it on the sharpmaker. It is that easy.
The 203 is the old model, comes in a cordura case, and has one angle (I believe it is a 40 degree angle, each side is 20 from vertical)
The 204 is a newer model, comes with an instructional video, and is encased in a hard plastic case. It has the capability to be mounted to a desk or work bench, and has both a 40 degree edge angle and a 30 degree back bevel angle.
Both models come with brass rods to protect your hands, medium grit triangular rods, and fine triangular rods. These will make knives sharp enough to remove hair from your arms, but not sharp enough to comfortably shave your face with.
To sharpen a knife, you must insert the ceramic rods into the holes. This will set the angle, and the new ones are labeled, one side says 40 degree edge, the other 30 degree back bevel. Even I can figure it out. Then you hold the knife straight out, with the edge down and spine up, and make a downward cutting motion first on one side, then the other. The only thing easier is cutting your thumb after you've sharpened your knife on this system. There are no clamps to attach to anything, or angles to set, or parts to assemble. There may be systems that can produce a sharper blade, and there are possibly a few that can sharpen a wider variety of things, though I doubt it. But I do not believe there is a system this simple and foolproof, this cheap, that produces such a sharp finished blade. I won't use it on my straight razor, but I do use it on everything else I cut with, from darts and fish hooks to kitchen knives, daily carry folders and scissors.
Stryver
The only time you need something else is when you have to remove MUCH steel from a VERY deteriorated edge.
Then use a Lansky or Gatco or Razor Edge or or or or.....
D.T. UTZINGER
Look at Joe Talmadge's sharpening FAQ under the "Knowledge" section of the site. Joe explains how to sharpen a knife and with the Sharpmaker and a coarse DMT or EZE Lap benchstone you can do it all.
The Sharpmaker's work great and are now packaged with an instructional video as well as book.
The new 204 model adds an extra angle for sharpening (30 degree included) as well as ready availability of spare rods should you drop one on a concrete floor (about the only way to break them).
Kevin Pensinger
The Edge Equipment
theedgeequipment@yahoo.com
]http://theedgeequipment.safeshopper.com
Contact THE EDGE for your cutlery needs!
I recently bought the Spyderco Sharpmaker 204 and it's about the only thing I've used since. If you watch the video first, you can really sharpen just about anything you want. For me the Sharpmaker is my favorite system that I have. I like it better than my Lansky 5 piece system.
These are my only gripes about the Sharpmaker:
- It's hard to do serious back-beveling or to re-sharpen a seriously dull knife on this system. Actually, it isn't really HARD, you just need a lot of patience as it can take quite a while. You might want an extra-coarse stone of some kind for serious re-sharpening.
- I wish it had two extra coarse sticks to go with the medium and fine.
- Personally, I have trouble using the flat sides of the stones because I haven't trained myself to make the stroke while still keeping the blade in full contact with the entire flat surface. The blade tends to lean toward one edge of the stone or the other instead of laying truly "flat" on the flat side (anyone else have this problem?) I can get a perfect edge on my knives using only the edges (corners) of the sticks (perfect for me may not be perfect for you, as I don't prefer a truly polished edge)
- If you use the edges of the stones (the corners, as opposed to the flat surfaces) you need to stop the sharpenig motion just before you get to the tip of the knife or you can actually grind the tip off fairly quickly.
Those are my only problems with the system and in my opinion, the benefits far outweigh the gripes. The spyderco system is so easy to use that my wife actually was able to put a really sharp edge on my Dad's Leatherman Micra (which is chisel-ground) and that was the first time she had ever tried to sharpen a knife of any kind!! She ground the tip off a bit, but all she did was watch the video and go for it. You will likely find that as with anything else, you need to practice a bit with it, and the more you do it, the better you'll get at it. I think this is the fastest (in terms of setting up), easiest, and most user-friendly system I've ever seen and would reccommend it to anyone without hesitation!
Wait... it comes with a video too?
How close to the factory edge does it get in terms of polish and clean grinding lines, etc? I'm almost obsessive compulsive. Right now I use the Lansky type system from Smith. Only costed me 20 dollars and it allows serration sharpening too.
