I think the extra cost for Super Blue well worth it for me.
The edges I get are super sharp with minimal effort.
I regularly carry carbon steel blades and am quite often getting wet at work, be it sweat or rain, and none of my blades have rusted away in the past 35 years of carrying.
Sure some stainless steels will give you similar performance to carbon steels but usually at a higher cost.
Also I believe the Super Blue sprints are all laminated so that is something to consider if worried about corrosion.
Eh, that really depends on what you use your knives for and how often. Super Blue has great edge retention and can have a very high hardness, but is FAR more prone to oxidation (patina, rust) and damage from impacts (chipping) than most steels you might be familiar with at this stage.
I would, quite honestly, recommend going with the VG-10 or S30V version of whatever knife you are looking at, because you probably won't be able to appreciate the difference until you have quite a bit of experience with different steels.
Edit: S30V and VG-10 are much lower-maintenance, as well. Those are steels you can use and just put right back in your pocket with minimal care. Super blue needs to be regularly coated with oil or marine tuff-glide, and should be wiped off after use. Get a good sharpening system (NOT A PULL-THROUGH) and practice and learn - you'll find there are price ranges where steels are almost interchangeable as long as you can touch up an edge.
Basically:
$10-60: 8Cr13MoV, AUS8A
$60-120: 154CM, S30V, VG-10
$120-200: CPM-154, M4, Elmax, CTS-XHP
$200+: M390, CTS-204p, S90V, S110V
All of these steels have their own individual properties, but typically have such similar edge retention that you aren't likely to notice day-to-day. Don't get too caught up in the steels as long as the price is right for what you're getting, and remember that the blade shapes and grinds will affect the edge retention and cutting abilities - not to mention your satisfaction with the knife - typically much more than the steels will in any given price range.
