- Oct 28, 2018
I just got a Spyderco UF bench stone but it's not flat, from what I've read this is fairly common, I've been having trouble flattening it on a diamond plate, does anyone know a faster way to flatten it?
SIC powder (silicon carbide)works great on a granite tile then use some wet/dry to finish it the way you want.
That method will prove difficult with a sintered ceramic stone. The way it usually works is by creating pressure concentration on the grains, which breaks the bond of the stone. That won't work very well here, as sintered ceramics are fused under incredible heat and pressure until the abrasive grains themselves have fused together. So you're basically limited to abrading the surface flat instead, and rubbing on free abrasive isn't a great way of accomplishing that. I'd use a cheap Chinese lapidary disk from eBay if I were going to bother with flattening one. Any diamond stone you use kind of has to be treated as disposable because it'll be used right up in the process.
