Hello,
I have new Spyderco Tenacious Lightweight. As usual out of the box clip is placed on the pivot side (tip down carry), opening and closing is quite smooth and blade centering is also OK (not perfect but not bad). As I prefer tip up carry I wanted to change clip position on the knife. But as soon as I loosen the clip screws (without touching pivot screw) I noticed the blade is suddenly too off center and opening/closing is too tight. If I loosen the pivot the blade centering is even worse and there is already also horizontal blade play. So it looks that everything is affected by those clip screws. Did anybody of you also notice that? And ideally is there any solution so I could use the clip in tip up carry position without those problems? Of course I can live with tip down carry but if there is something what can I do I would try it.
Thank you.
Thank you.
