- May 14, 2010
I found this thread: http://www.bladeforums.com/forums/s...Low-Rider-Pocket-Clip-for-7-USAKnifeMaker-com
Which pointed me to this item: http://usaknifemaker.com/folding-kn...t-clip-formed-tumbled-040-low-rider-thin.html
I used a 9/64 drill bit to make the holes larger, which worked much faster than the file I am sure.
I also drilled them from the back so that the clip would not get messed up or marks on it.
I also used an Extra-Coarse DMT diamond stone to thin out the side that has the screw holes in it, since the stock screws were too short.
All in all it wasn't to hard, but i had to keep going back and drilling the holes larger until i found the right size.
Even with them drilled out to 9/64 it is a tight fit (the holes in the knife are a little bit farther apart than these)
I've got a fully serrated tenacious on the way which I will probably add one of these to it also.
I put the extra screw in the bottom hole on the opposite side so I don't lose it
