777 Edge
Dealer / Materials Provider
- Sep 16, 2019
Hi guys,
For any of you following my thread on my Free 3D printable LeadingEdge sharpening system, "zyhano" and I were discussing designing adapters for the Sharpmaker.
I have 3D designed 19 different adapters to give your Sharpmaker a total of 14 extra angles to choose from, starting at 20 degrees inclusive (10 degrees per side), all the way to 60 degrees inclusive (30 DPS).
They slot into the Sharpmaker 30 degree "backbevel" slots.
Be sure to 3D print or CNC mill 2 of each one you want tot use (1 for each of your rods.)
If you don't have your own printer, then I suggest only having 1 adapter printed to start with and to see if it works with the shop's print settings, and if the print is accurate enough. Once you have tried 1 adapter and it works, then have the ones you want printed.
Here is where you can download my models in STL file format for 3D printing:
https://www.thingiverse.com/thing:4755125
Enjoy!
Note - Edit to original post - I added more angle options.
Enjoy!
